he's into euro now. it still sits the same way with the new owner.
Wheel fitment thread.
This is a sticky topic.
yep you will have no problem with thoseOriginally posted by Indie View PostI need some help guys. :/
Will 17x8 +35 with 225/45 all around fit on an R32 GTS-T?
Picked up some rims with tires, planning on changing rubber size soon though.Check out Top Tier Imports. Sign up today! http://www.toptierimports.com
Completely clueless as to wheel fitment but would anyone be able to tell me how a 18x8" rim with 35mm offset would fit on a gts sedan? I don't have rubber for them at the moment or I would just test fit them.
Sent from my iPhone using TapatalkOriginally posted by Robskido you really want something a guy with a Civic has?
8s would be slightly inside if not flush with the fenders.Originally posted by krystalized_jdm View PostCompletely clueless as to wheel fitment but would anyone be able to tell me how a 18x8" rim with 35mm offset would fit on a gts sedan? I don't have rubber for them at the moment or I would just test fit them.
Sent from my iPhone using TapatalkCheck out Top Tier Imports. Sign up today! http://www.toptierimports.com
Hey guys, quick question.
Right now i have 17x8 +38 w/~5mm spacer in front and 17x9 +42 in the rear. The rear fenders are already rolled and I have a set of HSD coilovers that are running about a 1" drop. Its pretty tame and i want something more agressive
After seeing Rush's car, i really want some MB Battles but im not sure whether to go for the 17x9 +30 or 17x9.5 +15. Also thinking maybe 17x9 +30 in front and 17x9.5 +15 in the rear.
the 9.5 +15 option will stick out an extra 27mm in the rear and 18mm in the front which doesnt sound too bad for the rear but not sure of the front will rub
I have a sedan so I would rather not have to pull the fenders and overfenders are kinda out of the question.
What's your opinion on this?
Edit: would prefer to avoid negative camber
This is how it looks pre-coilover, its about an inch lower now but I dont have pics as i lost my phone
If you need a clutch safety switch or daytime running lights to pass inspection, pm me and I can tell you how to do it for free
1991 Skyline GTS-t 4 Door
This is how she sits now. As you can see there is a bit of room to poke out more
depending on the tire you run the front wont have rubbing issue. i am running a 215/45 in the front and have rubbing issue on big bumps only on the fender liner. if you're only doing a inch lower you will be fine.Check out Top Tier Imports. Sign up today! http://www.toptierimports.com
Thanks, i have a 215/40 on the front now but its only 8" so we shall see how that goes. I will probably have to wait till fall to order though, gotta save up and pay off other things
edit: also, how pulled are your fenders? mine are rolled but not pulledLast edited by supreme; 07-31-2013, 11:13 PM.If you need a clutch safety switch or daytime running lights to pass inspection, pm me and I can tell you how to do it for free
