If you what to get 17x11 in w/e offset, you will need atleast 20mm over fenders. 255 tires would work, you don't need 225 on 11s.
Wheel fitment thread.
This is a sticky topic.
Wheels: 17x9 +20 Wedsport SA90's
Tires: 235/40ZR17 Yokohama S-Drive rubber
Camber: -2.25 front, -2.0 rear, needs another alignment so specs may be off.
Lip roll front and rear, basically flush. Might lower the front some more.
**Updated pics.
'12 STi Sedan
I'm looking at getting these:
5zigen FN01R-C (Hot Version)
front: 17x10 +35 245/40/17
rear: 17x10 +25 255/40/17
Falken ZE-912's
any idea how these would fit a gts-t?
I know they would need a fender roll, but anything else?Kevin S.
Current: 1992 Skyline GT-R (on the way!)
EX - 1995 BMW E36 M3
EX - 1993 Silvia S14 w/S15 Front
EX - 1990 Skyline GTS-T Type M
You might run into issues of the wheel rubbing the coilover in the front with that size.Originally posted by skylineftw View PostI'm looking at getting these:
Falken ZE-912's
Hey Burly, nice wheels!! Lower the front n rear a tard bit, maybe half an inch and your car will be perfect!!
Finally there are more GTS-t guys that know how to fit their wheels!!! Prop for you mate!!
Hey Guys,
I have a 1993 GTS-T soon to be lowered 30mm or so. I can get a great deal on a used wheel and tire combo that I've been told came off of a R33.
Here are the specs.
F 235/45/17 on a 8 inch with +32
R 255/40/17 on a 9 inch with +38
Will it fit without any modifications?
cheers
will fit easily, not aggressive enough for my taste but u wont have fitment issues.Originally posted by Futura View PostHey Guys,
Here are the specs.
cheers
You sure it will clear? 9 inch rear with a +38 offset in rear running 255s, I don't think it will clear the coilovers.
http://www.wheelsmaster.com/rt_specs.jsp
I put in the sizes you said for the rear, it'll be 1 inch closer to the inside.
Package is 25 mm (1'') closer to suspension/brakes components. Make sure that you have enough room for that. If not, consider lower offset, narrower tires or using spacers.
i would really like to hear everyones input on wheels for my car,
my options are 17x9 +35 or +15 and 17x10 +35 or +25,
im willing to do some rolling and mild pulling but i want a clean looking wheel that has some solid fitment and would fill out a aero kit nice. I think i may have to run a small spacer to dial the fitment in though.
thanksJesse
1990 HCR32
2006 Chev Silverado
