OK so i did some research (2 mins max on google) and found that diameter is the main issue. So as long as i keep the overall diameter I shouldn't run into any attessa problems. Now i need to know how sensitive the attessa is because i ran the tire size of choice through some calculator on 1010tires and it comes out to be a 0.23% in difference of diameter. If i'm limited to using same size on all fours then that probably means i can go 9inch widest =(.
Apparently stock IS250 AWD has the option of staggered?
do it up man.
