Actually, setting up a relay and a clean fuel pump re-wire with the battery in the trunk (Relocated) it's super easy.. i may just do this;
Cool beans, i'll try it out and see!Originally posted by M13 View Postzero issues, pump is stable at 12.7V in boost on the dyno.Check out the GTST Projects page and keep up to date with my build!
Toyed with the idea of making a brake master cylinder stopper as the typical Cusco units are rather overpriced (100$ ballpark - http://www.rhdjapan.com/cusco-bcs-ki...-group-a-10798) , and being that I couldn't fathom the absolute necessity to have one, I figured it'd be best to see what could be made!
Using some steel flat bar, I managed to come up with this.
Disregard the weld 'neatness', as i had the feed set WAY too high and was in a rush amidst arranging a few personal issues.
Now, after i designed it and put it together, i completely left the strut brace out the equation! Fortunately, it all fit without an issue;
I've ground the welds and painted it black. For a prototype, i think it turned out quite well!
It's adjustable, as well.
If anyone's interested, more can be had for a very fair price
Last edited by nelsonmxmarc; 02-02-2011, 12:51 PM.Check out the GTST Projects page and keep up to date with my build!
AW YOU'RE SO COOL MITCH!Originally posted by mitch32 View PostMy fuel pump is wired directly to the battery I get around 14V when the car is on. Never had an issue.
LOL
How'd you run the wiring? Did you use the SAU guide or just ran 8awg wire to the existing fuel pump loom? In the case you'd need a relay otherwise it'd run constantly?Check out the GTST Projects page and keep up to date with my build!
Adam, check this out! I did a somewhat, laments description here;
Frank, doesnt move one bit. Had the pedal to the floor, didn't deflect one bit. In fact, the bolt head imprinted itself into the BMC body. You can't dismiss the fact that it's 1/8th inch steel, and that the direction of force is contrary to the direction of its mount (Behind, and in a straight line). Had it been only the single piece of metal from the strut bolt down, then of course you'd see flex. The added benefit of structural support in the opposing direction adds the proper rigidity; it's effin stiff.
Mac book has no 'paint', or at least a substitute for paint, that i can see. So no drawings! But you get the point.Check out the GTST Projects page and keep up to date with my build!
Originally posted by archaeic_bloke View Postyo where did u get ur digital vernier caliper? my stupid solar powered one got depleted, now it doesn't understand anything or display anything meaningful... its junk. lolFowler High Precision is recognized as one of the world's leading suppliers of high-quality inspection, control and calibration equipment. We continue to introduce new innovations in inspection and measurement in the metrology space. Fowler continues to Making Measurement Easy!
I have the older model of this guy! Minus the flashy ruler .. lol
Very nice, and accurate, no issues whatsoever.
Yea, i can imagine solar powered tools work GREAT in the darkness of a workshop. I know what to get you for xmas now!!! UV lights
Thats the one that doesn't work!! hahahahah mastercraft fail on the solar powered caliper.Originally posted by frankiman View Postmastercraft @ canadian tire
yo marc, where can i buy the Fowler? thats what I need... I need a really good accurate one,The SkyLife Community & News Website --> http://www.skylife4ever.com
